Hi Allen,
I was thinking to create a range of notification messages that would pass a corresponding Mach3 DRO into a KFlop persist.UserData variable as a 32 bit floating point number. So for example if the assigned notification message range was 19000 to 19099. To transfer Mach3 DRO #7 to KFlop UserData[7] you would need to execute NotifyPlugins(19007).
Message: 897 |
Date: 2/2/2011 |
Subject: Re: Pass a variable from Mach3 to the homing routine |
Good thought! Keep in mind that valid user DRO range in Mach3 is 1001-1255.
When do you think something like that could be incorporated? :)
> Hi Allen,
> From: ca_gray751 <agray@...>
> Sent: Wed, February 2, 2011 9:46:14 AM
> Subject: [DynoMotion] Re: Pass a variable from Mach3 to the homing routine
> Tom,
> Any thoughts on this? I know we talked about this once before via email. I went
> through some past emails and found some dated 12/17 where you had an idea on how
> to handle this situation.
> Thanks,
> Allen
> --- In DynoMotion@yahoogroups.com, "ca_gray751" <agray@> wrote:
> > Tom,
> > Is is possible to pass a number from a mach3 user dro to the homing routine?
> > Every now and then a table operator has to check for table squareness and needs
> >a way to make small adjustments so the slave motor will move off the home prox
> >slightly more or less than the master motor.
> > Thanks,
> > Allen
Message: 902 |
Date: 2/3/2011 |
Allen,
Here is a new plugin that should work with V4.23. Copy to your Mach3/Plugins directory.
It should report as V4.23d
Below is a description and example.
Let me know if it has any problems.
Mechanism for transfering values back and forth between Mach3 and KFLOP
Mach3 User DROs 1 to 50 map to KFlop UserData 0 to 99 (2 words each double)
To Read from KFLOP to Mach3 use NotifyPlugins codes 18001 to 18050
To Write from Mach3 to KFLOP use NotifyPlugins codes 19001 to 19050
Example MACH3 SIDE
SetOEMDRO(1007,123.456) 'Put a value in a Mach DRO NotifyPlugins(19007) 'Send it to KFLOP Sleep(3000) 'Wait for KFLOP to modify and copy it NotifyPlugins(18008) 'Read the result from KFLOP x=GetOEMDRO(1008) 'Check the value passed back
Example KFLOP SIDE
#define DROIN 7 #define DROOUT 8 main() { double *pin = (double *)&persist.UserData[(DROIN -1)*2]; double *pout = (double *)&persist.UserData[(DROOUT-1)*2];
for(;;) { Delay_sec(2); *pout = *pin + 999; printf("DROIN %d = %f DROOUT %d = %f\n",DROIN,*pin,DROOUT,*pout); } }
Message: 903 |
Date: 2/4/2011 |
Thanks Tom. I will test this when I get back in the office on Monday.
Allen
> Allen,
> directory.
> http://www.dynomotion.com/Software/Mach3DRO/Dynomotion.dll
> Thanks
> Example MACH3 SIDE
> SetOEMDRO(1007,123.456)Â 'Put a value in a Mach DRO
> NotifyPlugins(19007)Â Â Â Â 'Send it to KFLOP
> Sleep(3000)Â Â Â Â Â Â Â Â Â Â Â Â Â 'Wait for KFLOP to modify and copy it
> NotifyPlugins(18008)Â Â Â Â 'Read the result from KFLOP
> x=GetOEMDRO(1008)Â Â Â Â Â Â Â 'Check the value passed back
> Example KFLOP SIDE
> #include "KMotionDef.h"
> #define DROIN 7
> #define DROOUT 8
> main()
> Â Â Â double *pout = (double *)&persist.UserData[(DROOUT-1)*2];
> Â Â Â for(;;)
> Â Â Â {
> Â Â Â Â Â Â Â Delay_sec(2);
> Â Â Â Â Â Â Â *pout = *pin + 999;
> Â Â Â Â Â Â Â printf("DROIN %d = %f DROOUT %d = %f\n",DROIN,*pin,DROOUT,*pout);
> Â Â Â }
> Sent: Wed, February 2, 2011 10:51:14 AM
> > Hi Allen,
> > floating point number.ÃÂ So for example if the assigned notification message
> > range was 19000 to 19099.ÃÂ To transfer Mach3 DRO #7 to KFlop UserData[7] you
> > From: ca_gray751 <agray@>
> > ÃÂ
> > Tom,
> >how
> > Thanks,
> > Allen
> > > Tom,
> >needs
> > > Thanks,
> > > Allen
Message: 940 |
Date: 3/6/2011 |
Actually, the range goes much higher than what the Wiki says. IT was increased at some point.
Not sure of the upper limit, but I think it might be 2000. I use UserDRO's in the 1800 range in my custom screen.
Gerry
